Server Error in '/' application. Attribu... (Solution 500000099259)
 Product(s):ProjectWise Web Server
 Version(s):08.11.11.111
 Environment: N\A
 Area: Attributes
 Subarea: N\A
 Original Author:Raul Guerrero, Bentley Technical Support Group
Server Error in '/' application. Attribute not found
Product: ProjectWise Web Server V8i
Version: 08.11.11.111
Area: ASPX Webparts, Problem ID#: 87544, PROBLEMSOLVING
We grabbed a copy of the user's database and found that the user had a
broken class editor. Once this class editor was removed, the web
server started working.
