| | Applies To | | |
| | Product(s): | SewerGEMS, SewerCAD, CivilStorm, StormCAD | |
| | Version(s): | 08.11.04.54 and greater | |
| | Area: | Layout and Data Input | |
| | Original Author: | Sushma Choure, Bentley Technical Support Group | |
How do I morph one element into other in storm-sewer products e.g. manholes into catchbasins, in batch (many at once)?
If you're using V8i SELECTseries 5 (08.11.05.58) or higher (including CONNECT Edition), use the Batch Morph tool located under the Tools menu.
For earlier versions: there are a couple of cases which can be considered;
- You want to convert all the manholes into catchbasins.
- You want to convert selected number of manholes into catchbasins.
Here is the workaround for doing that.
Considering case 1 – converting all manholes into catchbasins.
- Select all the manholes which you want to morph into Catchbasins by going to Edit>Select by Element >Manhole>Right click>Create selection set (so you can get back to that selection later).
- With the Manholes selected, right-click >Edit Group>Manhole Table.
- Add the desired columns like x & y co-ordinates column & Label column to flex table by editing and export to shapefile name, it as e.g. "catchbasins.shp". (Keep the Manhole FlexTable open for Step 5).
- Open a Conduit FlexTables, include the StartNode and StopNode columns, and export to shapefile (e.g. "conduits.shp").
- Relabel your Manholes (so that your catchbasins will not have duplicate labels).
- Use ModelBuilder to import the "catchbasins.shp" shapefile as Catchbasins.
- Use ModelBuilder to import the Conduits (to reconnect the conduits to the Catchbasins).
- Select the Manholes (e.g. using the Selection Set from Step 1) and Delete.
Considering case 2 – converting selected number of manholes into catchbasins.
- Select only those manholes which you want to morph into Catchbasins>Right click>Create selection set (so you can get back to that selection later).
- Steps 2 to 8 are same as above.
