| Product(s): | WaterGEMS, WaterCAD, SewerGEMS, SewerCAD, StormCAD, CivilStorm, HAMMER, PondPack | |
| Version(s): | 10.00.xx.xx, 08.11.xx.xx | |
| Area: | Output and Reporting |
How can you change the printer size for printing a report in the software?
Problem ID#: 58021
Paper sizes are associated with the printer itself. The program will pull printing options from the printer itself, and different printers will have different paper size options.
To change the size, make sure that you have first selected the correct printer as the default. This can be done your computer itself, such as through the Control Panel. Once this is done, open the print preview for the report and select File > Page Setup. You can then change the paper size. If the paper size is not available, you may want to select a different printer as the default printer.
