| Product(s): | WaterCAD, WaterGEMS |
| Version(s): | 08.11.XX.XX and 10.00.XX.XX |
| Area: | Output and Reporting |
Why is the flow data missing from the Simulated Results tab for an optimized solution?
[Problem Number ID#: 31426]
Flow results are only displayed in the Simulated Results tab if you have discharge field data specified for pipes, under the "observed target" tab of the "field data snapshot" section of the calibration study.
[Solution ID#: 500000058318]
