| Product(s): | WaterGEMS, SewerGEMS, CivilStorm, StormCAD, PondPack, SewerCAD, HAMMER, WaterCAD, WaterOPS, SewerOPS | ||
| Version(s): | CONNECT Edition, V8i | ||
| Area: | Modeling | ||
| Original Author: | Mark Pachlhofer, Bentley Technical Support Group |
How can I create multiple views of my model for easier display?
In order to do this you will use the named views (View > Named Views) tool. Named Views allow a user to store the current views X and Y coordinates. When you set a view in the drawing pane and add a named view, the current view is saved as the named view. You can also update a named view using update icon see in the screen shot below. All you would do is change the view or zoom of the data frame and then with the named view you want to change highlighted in the named views manager just click the update icon.
The icon directly to the left of the update icon is the "Go to View" button that will bring up the saved named view once the named view label is selected and the "Go to View" button is pushed.
