Conduit catalog entries not available in Properties
Product(s):StormCAD, SewerCAD, SewerGEMS, CivilStorm
Version(s):10.00.xx.xx, 08.11.xx.xx
Area:Modeling
When trying to select a new conduit type from the Conduit Catalog by highlighting the conduit in the catalog and selecting the Select button, the conduit doesn't appear as an available selection in the conduit properties grid.
Problem ID#: 85995
If the item you are trying to select from the conduit catalog is different from the Section Type in the conduit properties, it will not be available for selection. Make sure that the Section Type in the Conduit properties is the same as the item you are trying to select. Only elements of a given Section Type will be displayed and available for selection.
 Original Author:Scott Kampa
