| Product(s): | WaterGEMS, WaterCAD |
| Version(s): | 08.11.XX.XX, 10.XX.XX.XX |
| Area: | Output and Reporting |
When attempting to use the post calculation processor tool, the following error occurs for V8i:
Bentley WaterGEMS V8i (SELECTseries 1) Problem
The result property and output property have no common supported element types.
Please choose a different result and/or output property that share common supported element types.
OK
Problem ID#: 51312
And for Connect Edition versions, following error is seen
Make sure to choose the correct "Result Property". For example if you're looking at a pump, do not choose the "Result Property" called "Flow", as that is not a result field for pumps. Instead, you would choose "Flow (Total)" property. To see the correct result properties available for each element type, look at that element's property grid or FlexTable.
Using the Post Calculation Processor for statistic analysis of reports
