| Product(s): | SewerGEMS, CivilStorm |
| Version(s): | 08.11.XX.XX, 10.00.XX.XX |
| Area: | Calculations |
When computing a long term continuous simulation model with a rain file and the Explicit (SWMM) solver, an error message called Error 318 is generated.
[Problem ID#: 71561]
The issue is likely related to inconsistent information in the Rain File, such as an incorrect date or bad formatting. Review the rain file to make sure the formatting is correct and check for incorrect dates, such as February 30th.
[Solution ID#: 500000088401]
What is the purpose the Rainfall File, Runoff File, and RDII File in the Calculations Options?
