| Product(s): | SewerGEMS, SewerCAD, StormCAD, CivilStorm, PondPack, WaterGEMS, WaterCAD, HAMMER |
| Version(s): | 08.11.XX.XX and 10.00.XX.XX |
Unable to set zone back to None "<None>" using ModelBuilder.
When updating a model's zone attribute using ModelBuilder, why do I get the following message?
"Warning: Unable to assign attribute "Zone" for element "P-1" because referenced element "<None>" does not exist."
[Problem #: 41084]
This is because the program is expecting a zone called "<None>" to exist in the zone manager and will not know that you meant to set it back to None.
Option 1: To set a zone back to <None>, leave that field/cell blank in your source data file.
Option 2: Create a zone in the zone manager called "<None>".
[Solution #: 500000067620]
