Is it possible to model more than one pump starting up at the same time?
 Product(s):Bentley HAMMER
 Version(s):08.11.xx.xx
 Area: Modeling
 Original Author:Scott Kampa, Bentley Technical Support Group
It is possible to model this situation. You would need to take care in setting up the nominal head and flow, being sure this is entered taking into account how the pumps will be when the transient simulation is completed.
Modeling a pump start-up transient event in Bentley HAMMER V8i
