| Product(s): | WaterCAD, WaterGEMS |
| Version(s): | V8i, CONNECT Edition |
| Area: | Other |
| Original Author: | Mark Pachlhofer, Bentley Technical Support Group |
Does the Top Fill Tank property factor into mixing?
Problem ID#: 53153
No, the Top Fill Tank property is just used for more accurate hydraulic grade line calculations. The tank mixing behavior is controlled by the 'Tank Mixing Model' property. For tips on which mixing model to use for a top-fill tank, see the first article below.
