Product(s): | Bentley WaterGEMS, Bentley WaterCAD | ||
Version(s): | 08.11.xx.xx | ||
Environment: | N\A | ||
Area: | Calculations | ||
Subarea: | N\A |
When computing a Darwin Scheduler run, the following error message is generated:
"Starting energy price must be greater than zero."
However, energy pricing is included and is greater than zero.
This user notification occurs if the energy pricing method is the Block Rate tariff type. Darwin Scheduler does not support Block Rate. Instead, it is recommended that the Constant or Time of Day tariff type.
Using Darwin Scheduler
Original Author: | Scott Kampa |
