| Product(s): | WaterGEMS, SewerGEMS, HAMMER | ||
| Version(s): | CONNECT Edition, V8i | ||
| Original Author: | Mark Pachlhofer, Bentley Technical Support Group |
What are some operations that I should NOT be performing in the ArcMap or ArcGIS Pro integrated versions of the OpenFlows software?
There are two operations that you should NOT perform when in ArcMap or ArcGIS Pro integrated versions of the software:
Performing either of these operations could potentially corrupt the feature class in the geodatabase or cause some kind of disconnect between the geodatabase and the hydraulic model files, making the files unreadable.
