| Product(s): | WaterGEMS, HAMMER, SewerGEMS |
| Area: | General |
What level of ArcMap license is required for WaterGEMS, HAMMER, SewerGEMS?
Problem ID#: 54641
An ArcView (Basic) license is sufficient. If more advanced ArcMap processing tools are required for your workflow, you will need a higher level. However, all features specific to WaterGEMS/SewerGEMS/HAMMER are available with ArcView.
As of version 10.1 of ArcGIS, the three levels of licensing are Basic, Standard and Advanced. Previously these were called ArcView, ArcEditor and ArcInfo, respectively.
