I have hatches in my DGN file that were exported to a DXF file and when brought in as a background f
Product(s):Bentley StormCAD, SewerCAD, SewerGEMS, CivilStorm
Version(s):V8i, Connect Edition
Area:Layout and Data Input
I have hatches in my DGN file that I have exported to a DXF file and when I bring it in as a background file the hatch marks don't display. How can I get them to display?
Problem ID#: 46022
Hatch marks in a Microstation DGN are not polylines. They are lines that are rendered by the program and displayed for visual purposes. If you want to make these lines polylines so they will show up in your DXF file you will need to use the Microstation "Drop" tool/function which will set the lines as individual polylines. This tool is very similar to the Explode tool/function in AutoCAD.
