| Product(s): | Bentley Hammer |
| Version(s): | V8i, Connect Edition |
| Area: | Output and Reporting |
Is it possible to print the results on the drawing pane when using the Transient Thematic Viewer?
Yes, it is possible to print the results from the Transient Thematic Viewer. Once you apply the results you wish to view, keep the Transient Thematic Viewer open. Then go to File > Print Preview > Fit to Page. The Transient Thematic Viewer can be minimized, if necessary.
The resulting image should include the color coding applied in the Transient Thematic Viewer. If you close the Transient Thematic Viewer before going to Print Preview, the results will not be displayed.
