| Product(s): | SewerGEMS, CivilStorm, SewerCAD, StormCAD, WaterGEMS, WaterCAD, HAMMER |
| Version(s): | 08.11.03.XX and higher |
| Area: | Help and Documentation |
How to search for key words or phrases in the properties grid?
Users can find the property they want quickly in the property grid using keyword search. To use this function, open the property grid for any element, by either double-clicking on the element or going to View > Properties. The new Property Search field is above the list of element properties. Simply start typing the word you are searching for and the property grid will dynamically filter to show any property field name that contains the phrase entered.
Recent searches are stored in the drop down selection. The search term is maintained even when selecting a different element or element type. To clear the selection, click the Clear button beside the drop down.
