| Product(s): | Bentley SewerGEMS, CivilStorm, PondPack |
| Version(s): | V8i, Connect Edition |
| Area: | Modeling |
The Storage Chamber feature has been available in Bentley PondPack as of version 08.11.01.51 as well as Bentley SewerGEMS/CivilStorm as of version 08.11.04.54.
This article explains how to obtain updated Engineering Library data for Brentwood Industries Storage Chambers. This update is from September 2014 and is compatible with Pondpack, SewerGEMS or CivilStorm (minimum version mentioned in previous paragraph.) If you have a version of these products released after September 2014, it may already include this update.
Models included:
ST-18
ST-24
ST-30
ST-33
ST-36
To download a copy of the Brentwood Industries Storage Chambers library, click the below link:
1) Download and save the updated Brentwood.xml file to a suitable location on your hard drive
2) Open the software and go to Components > Engineering Libraries
3) Right click on "Storage Chamber Library" in the list and choose "Add existing Library..."
4) Browse to the location where you saved the Brentwood.xml file to and double click it. It should now appear in the engineering library.
6) Click the close button. You can now use the Brentwood Industries storage chambers.
To use Brentwood Industries storage chambers after the above installation:
1) Open the software and go to Components > Storage Chambers.
2) Click the Synchronization Options button (purple book icon) and choose "import from library"
3) Expand Brentwood.xml and select the storage chamber model you'd like to use (ST-18, ST-24, etc) and click "select"
4) The storage chamber will now appear in the storage chamber manager and can be selected in the properties of a pond, with the pond type set to Storage Chamber System. Review the data for the model selected. If you'd like to import another storage chamber, repeat steps 1-4.
5) To use a Brentwood Industries storage chamber for a pond, open the properties of your pond polygon element in the drawing plan view and select Storage Chamber System for the Pond Type field.
6) In the Storage Chamber field, select the model that you had imported into the Storage Chamber Manager.
7) Enter the parameters of the chamber system rows and columns and surrounding fill. For more on this, see "Setting Up a Storage Chamber System in the Model" in the below Technote:
Entering Underground Storage Chamber Information
If you have more than one compatible product (such as PondPack and SewerGEMS or SewerGEMS and CivilStorm) and would like to use this updated library in both/each of them, you can either save multiple copies of the Brentwood.xml file and browse to each respective file within the product's Engineering Library Manager, or you could simply save a single file and browse to that from each product.
