| Product(s): | Bentley SewerGEMS, SewerCAD | ||
| Version(s): | 08.11.XX.XX | ||
| Area: | Layout |
I have a wetwell with varying dimensions at different elevations. How do I correctly enter this information using the "Depth-Area" option for the "Section" input field in a wetwell?
The "depth-area" option for a wetwell expects a table of depths (measured from the bottom of the wetwell) versus equivalent cross sectional area.
So for example let's say you have an irregular wet well that is 5 m x 3.6 m between elevation -1.9 m and 0.049 m and that is 3.95 m x 10 m between elevation 0.049 m and 8.25 m.
In this case you would enter an area of 18 m^2 between a depth of zero and 1.949 m and an area of 39.5 m^2 between a depth of 1.949 and 10.15.
