| Product(s): | Bentley StormCAD, SewerCAD, SewerGEMS |
| Version(s): | 08.11.XX.XX |
After running the design analysis, the conduits are not designed, although it is set to Design Conduits = true. What can I check for?
Problem ID#: 46266,
Please check the following
· The Calculation Type under Calculation Options has to be set to "Design". Check to see if Conduit type is set to "Catalog Conduit", as this has to be set so StormCAD can design the conduit from the catalog.
· Also, under Components > Catalog Conduit, make sure that the desired conduits have "Available for Design" checked.
· Go to Analysis>Alternatives>Design Alternative and check if all conduits are set to design yes.
· If all the above are correct, then check the article in the Help about Design Constraints, found under Contents > Creating Models > Automatic Design > Default Design Constraints
