| Product(s): | StormCAD, CivilStorm, SewerGEMS |
| Version(s): | 10.00.xx.xx, 08.11.xx.xx |
| Area: | Modeling |
InRoads crashes when viewing and editing a model imported from a storm-sewer product, like CivilStorm or StormCAD.
The issue is due to a character limit for the Material field in InRoads. To resolve the issue, edit the Material field in the storm-sewer product before exporting the model into the InRoads format. The name in the Material field should be less than 20 characters. Once this is done, the issue will no longer occur when viewing or editing the model in InRoads.
How does StormCAD integrate with InRoads, PowerCivil, and GEOPAK?
