| Product(s): | Bentley PondPack |
| Version(s): | 08.11.XX.XX |
| Area: | Modeling |
What are Cipolletti Sharp Crested Weirs?
HS1122136
These weirs are trapezoidal shaped with 1:4 side slopes to compensate for end contraction losses. The bottom of the notch should be set above the upstream channel bottom a height of at least twice the maximum head, preferably more.
communities.bentley.com/.../23292.units-for-v-notch-vs-rectangular-vs-irregular-weir
