| Product(s): | WaterGEMS, SewerGEMS, CivilStorm, StormCAD, PondPack, SewerCAD, HAMMER, WaterCAD | ||
| Version(s): | 08.11.XX.XX | ||
| Original Author: | Mark Pachlhofer, Bentley Technical Support Group |
How can I simulate a flywheel on a pump to reduce a transient?
A flywheel can be simulated by increasing the inertia on the transient tab in the pump definitions manager (Components > Pump Definitions).
Please make sure to keep this information in mind when considering using a flywheel for protection against a transient:
a) They are usually big and heavy, so the pump station needs to be designed to accommodate them
b) They require extra energy each time you start the pump. As a result of the extra energy required the pump may need a larger motor
Does HAMMER account for water in the pump for inertia calculations?
