| Product(s): | StormCAD, CivilStorm, SewerGEMS | ||
| Version(s): | 08.11.02.75 | ||
| Area: | Layout and Data Input | ||
| Subarea: | N\A |
Is is possible to open a WinStorm file (.stm) directly into StormCAD, CivilStorm or SewerGEMS?
Problem ID#: 67345
While StormCAD version 5.6 files are also .stm files, it is not possible to directly open a WinStorm file in StormCAD, since the formatting of the data within the file will be very different. As a workaround, you can try to export the WinStorm model into a LandXML format. This would need to be done within WinStorm itself. Once the file is converted into a LandXML file, you can then import the .xml file into StormCAD by going to File > Import > LandXML.
How to import or Open a InfoSWMM, Mike Urban, LandXML, or other competitor product?
| Original Author: | Scott Kampa |
