| Product(s): | Bentley WaterGEMS, WaterCAD, HAMMER, SewerGEMS, SewerCAD, CivilStorm, PondPack | ||
| Version(s): | 08.11.XX.XX | ||
| Area: | Output and Reporting |
How do you change the colors for a the lines, bar, or dots in a graph?
Problem ID#: 80512
The way to customize the color of the lines, bars, dots, etc. is by opening the Chart Options from the icon at the top of the window (or right click in the graph > Chart Options)
and then by double clicking on the line color which is to the right of the check box on the Series tab for the charts. The window, by default, will open to this tab.
