| Product(s): | WaterGEMS, WaterCAD |
| Version(s): | 10.00.XX.XX |
| Area: | Output and Reporting |
When computing a model the following user notification appears:
"Demand at least for one customer meter could not be distributed as specified. Demand completely loaded at valid end node. Run full validation for details."
When validating the model the following user notification appears:
"Cannot distribute ##.#% customer demand to <Node Type> "<Node Label>" of associated pipe <Pipe Label>."
This yellow user notification is informational. It is letting you know that a customer meter's configured percent distribution cannot be satisfied because an end node of the associated pipe cannot accept demands (eg. a valve). In this case 100% of the customer meter demand will be applied to the associated pipe's end node that can accept demands (eg. junction or tank).
Customer Meter Elements and the External Customer Meter Data Manager
Using LoadBuilder to assign Customer Meters to the nearest pipe using taps and laterals
