| Product(s): | CivilStorm, SewerGEMS |
| Version(s): | 08.11.XX.XX and 10.00.XX.XX |
What is the purpose of the "weir end coefficient" when using a trapezoidal weir for a control structure in SewerGEMS/Civilstorm?
The "Weir End Coefficient" is the discharge coefficient for flow through the triangular ends of the trapezoidal weir (green portion in the image below).
Note:
The "Weir Coefficient" is the discharge coefficient for flow through the central portion of the weir (blue portion in the image below). It is also known as the coefficient of flow. This value is used to account for variables that are not otherwise directly accounted for in the weir equation (eg. vena contracta).
These coefficients are used to calculate the flow in the weir with the following equation.
Where:
Q = flow
L = crest length
h = head above weir
C = weir coefficient
Cs = weir coefficient for the side section
Help Topic "Trapezoidal Weir"
How is the headloss for a weir calculated in the control structure for the storm and sewer products?
