| Product(s): | WaterGEMS, WaterCAD |
| Version(s): | 08.11.XX.XX |
| Area: | Modeling |
When attempting to open WaterCAD or WaterGEMS in AutoCAD, the following error occurs:
Exception in C:\Program Files\AutoCAD Civil 3D 2010\AeccDbMgd.dll ARX
Command
Unhandled Exception
[Problem # 61669]
Close AutoCAD and go to Start > Programs > Bentley > WaterCAD/WaterGEMS > Integrate WaterGEMS with AutoCAD-MicroStation-ArcGIS
If this does not help, try doing a repair on the WaterCAD/GEMS installation, from Control Panel > Add/remove programs.
[Solution # 500000082041]
AutoCAD Integration Troubleshooting
Error opening the AutoCAD integrated version of the software: Class not registered
