| Product(s): | WaterGEMS, WaterCAD, HAMMER, SewerGEMS, StormCAD, SewerCAD, CivilStorm, PondPack |
| Version(s): | 08.11.XX.XX and 10.00.XX.XX |
| Area: | Calculations |
Can a user data extension with an IF, THEN, ELSE (iif) statement assign a value to another field?
For example, the statement below would result in the following error.
iif( [DerivedNodeResults_StructureDepth; Feet] >=10, [CircularStructureType_Diameter; Feet] =4, [CircularStructureType_Diameter; Feet] =3)
Error: "User Data Extension Problem: Error found in provided expression. Details: Incompatible returned data-type from this expression with respect to the one expected."
The "iif" statement can be used in a user data extension to report values. Then those values can be copied and pasted to the desired input field using a FlexTable.
For the example above, the following statement could be used.
iif( [DerivedNodeResults_StructureDepth; Feet] >=10, 4, 3)
Then those values could be selected in the element's FlexTable, copied, then pasted into another field.
How do you create an IF / THEN / ELSE statements using Formula derived user data extensions?
Copy and paste (import or export) tabular data
Query, alert or formula UDX not working correctly with "=" (equals)
