| Product(s): | CivilStorm, SewerGEMS, StormCAD, SewerCAD | ||
| Version(s): | CONNECT Edition, V8i | ||
| Area: | Layout and Data Input | ||
| Original Author: | Scott Kampa, Bentley Technical Support Group |
How can you open an InRoads Storm and Sanitary drainage database (SDB) into the Storm/Sewer products?
InRoads Storm and Sanitary models can by imported into a Storm/Sewer product by going to File > Import > InRoads. You will then be able to import the drainage database and supporting files. See the following Help topic for more information and assumptions: "Importing from InRoads."
It is also worth noting that the Hydraulics and Hydrology calculations and tools are incorporated into OpenRoads Subsurface Utilities. The following link has more information on this: Understanding Hydraulics and Hydrology Functionality in Subsurface Utilities
