| Product(s): | StormCAD, CivilStorm, SewerGEMS |
| Version(s): | 10.XX.XX.XX and 08.11.XX.XX |
| Area: | Calculations |
If a catchment has a time of concentration less than the smallest duration in the IDF table, how is the intensity determined?
For Example:
If the following catchment's Time of Concentration is 5 minutes, and the lowest duration in the IDF table is 10 minutes, then how is the intensity calculated?
The intensity, corresponding to a time of concentration that is less than the lowest duration value in the IDF table, is determined by extrapolating the line from the two lowest points of duration and intensity in the IDF table.
The IDF table equation storm data isn't producing the correct intensities in my catchments.
