| Product(s): | WaterGEMS, SewerGEMS, CivilStorm, StormCAD, SewerCAD, Hammer, WaterCAD |
| Version(s): | 08.11.XX.XX, 10.XX.XX.XX |
Why doesn't my load use type field show up in the "population density type" field in Loadbuilder?
Why doesn't my land use type field show up in the "land type field"field in Loadbuilder?
Problem ID#: 48669
LoadBuilder expects the Land Use Type field to be a text field (not a numeric field). Some LandUse shapefiles just use a numeric code. If this is the case, you will need to convert your land/load use type field to a text data type through your GIS software.
Troubleshooting and Understanding LoadBuilder
