| Product(s): | WaterGEMS, WaterCAD |
| Version(s): | 10.XX.XX.XX, 08.11.XX.XX |
| Area: | Help and Documentation |
What is difference between Colebrook White Coefficient and Darcy Weisbachcoefficient. Convert coefficient, roughness factor, roughness height.
Problem ID#: 71119
The Colebrook-White equation is used to iteratively calculate for the Darcy-Weisbach friction factor: Colebrook White Coefficient and Darcy Weisbach coefficient are same in water products.
What is the difference between Darcy-Weisbach roughness coefficients e and f ?
Darcy-Weisbach Headloss Calculations in Steady State and EPS
