| Product(s): | WaterGEMS, WaterCAD |
| Area: | Modeling |
| Original Author: | Mark Pachlhofer, Bentley Technical Support Group |
Are demand patterns used a steady state simulation?
By default, a steady state simulation uses the base demands entered at node elements. Demand patterns are not considered. If you want the pattern to be consider, you will need to use the EPS Snapshot feature.
Using EPS Snapshots to apply demand patterns to a steady state simulation
