| Product(s): | SewerGEMS, StormCAD, CivilStorm, PondPack |
| Version(s): | 08.11.XX.XX 10.00.XX.XX |
Why don't the IDF equation coefficients match?
What happened to the E, B, D coefficient IDF curve type?
IDF curve equation coefficients E, B, and D are now labeled A, B, and N.
[Problem ID#: 39295]
The naming of the coefficients in the IDF curve equation format has changed in V8i.
Mapping for the new naming convention is as follows:
e -> n
b -> a
d -> b
Other sources may use different characters for the IDF equations.
Coefficients that are in the same place, in a matching equation, can be considered equivalent.
Wiki: Import IDF Equation Storm Data
Forum: IDF Curve Equation_StormCAD
