| Product(s): | WaterCAD, SewerGEMS, WaterGEMS, StormCAD, CivilStorm, SewerCAD, Hammer |
| Version(s): | 08.11.XX.XX, 10.XX.XX.XX |
Is it possible to change the font for text in DXF backgrounds and annotations?
Problem ID#: 43584,
Yes, to change the font of the text in DXF backgrounds as well as annotations, click somewhere in the drawing pane and press Shift + f. A dialog box will appear, where you can select a different font, size and style. Additional fonts can be added from "Fonts" under the Windows control panel.
Please note that this is an uncertified feature, which should be used at your own risk.
Text, cells/blocks and line styles do not display correctly in a DXF background layer
