Paging file is too small for this operation to complete
Product(s):SewerGEMS, SewerCAD, CivilStorm, StormCAD
Version(s):08.11.XX.XX
Area:Calculations
When trying to compute a model, the following error occurs:
"The paging file is too small for this operation to complete"
Problem ID#: 65634
Try adjusting your Windows page file setting:
1.) Start, Control Panel, System
2.) The system properties applet will appear, Select the advanced tab
3.) In the performance tab, click settings
4.) The performance dialog will appear, click the advanced tab click the change button
5.) You will now (assuming that you are a local admin) be able to increase the size of you virtual memory.
6.) Change the paging size and click set.
7.) Click OK
8.) Click OK
9.) Click OK
10.) At this point the machine may need to re-start.
Also, make sure you have sufficient free disk space on the hard drive used to store the Windows temporary folder. (typically the C:\\ drive)
Column wrapping issues in reports
Memory errors when performing certain tasks
