| Product(s): | WaterGEMS, WaterCAD | ||
| Version(s): | 08.11.XX.XX | ||
| Area: | Modeling |
Can a node be a constituent source?
Problem ID#: 67478
Yes, to model a constituent source, you can set the "Is Constituent Source?" property of a node to true (from Property Grid or Flex Table). This should only be used where the node is a source of chemical constituent (e.g., dosing station) or flow entering from un-modeled system.
Understanding Constituent Source Types and Constituent patterns
