| Product(s): | Hammer |
| Version(s): | 08.11.XX.XX |
| Area: | Modeling |
Does the Extended CAV option apply to vapor pockets in the system or only air?
The Extended CAV calculation option only applies to air, and only at air valve nodes (whose elevation is higher than the two adjacent nodes).
Modeling Reference - Air Valves
Assumptions and limitations of tracking air or vapor pockets in HAMMER
