Product(s): | CulvertMaster | ||
Version(s): | 03.xx.xx.xx | ||
Area: | Modeling |
When computing an analysis, the following error message is occurring:
"Runtime Error: ZeroDivide"
First, if you are not already using the latest version of CulvertMaster, upgrade using the information in this link. As of February 2019, the latest version is 03.03.00.04.
If you are already using the latest version, please install the latest available cumulative patch set. The latest patch set can be obtained from Bentley Technical Support.
