| Product(s): | WaterGEMS, SewerGEMS, HAMMER |
| Version(s): | 08.11.05.61+ (WaterGEMS & HAMMER) and 08.11.05.58+ (SewerGEMS) |
| Area: | Other |
How can I integrate WaterGEMS, SewerGEMS or HAMMER with ArcGIS 10.3?
The Process for Integrating ArcGIS 10.3 with SewerGEMS and WaterGEMS
WaterGEMS and HAMMER
ArcGIS 10.3 is fully supported starting with the V8i SELECTseries 6 (08.11.06.58) release of WaterGEMS and HAMMER.
For WaterGEMS and HAMMER V8i SELECTseries 5 (08.11.05.61) it is supported by way of a patch. This addition is included in the latest cumulative patch set for this version, which can be downloaded from our website. See the below articles for assistance with downloading. If the latest patch is not yet available on the download site, please contact technical support. See additional steps further below for how to integrate after applying the patch.
SewerGEMS
Officially tested and certified ArcGIS 10.3 support has been added as of SELECTseries 5, build 08.11.05.58. See below article for how SELECT subscribers can download the latest version. See additional steps further below for how to integrate after applying the patch.
Additional Steps Required to Integrate
As of May, 2015, a patch to ArcMap 10.3 and 10.3.1 is required from Esri in order for WaterGEMS, SewerGEMS and HAMMER integration to work properly. This patch addresses an issue on the ArcGIS side. It is possible that future versions or updates to ArcGIS 10.3 will include this fix. In the meantime, please use the below steps.
If you have 10.3 or 10.3.1, follow these instructions once you have installed SewerGEMS 08.11.05.58 (or greater) or WaterGEMS 08.11.05.61 (with the latest cumulative patch installed) or HAMMER 08.11.05.61 (with the latest cumulative patch installed).
1. Visit the following link: http://support.esri.com/en/knowledgebase/techarticles/detail/43712
Under "Solution or Workaround" (You have to scroll down a little to see this.) download the ESRIRegAsm.exe.config.zip file.
Unzip and copy it to C:\Program Files (x86)\Common Files\ArcGIS\bin on a 64-bit Windows OS
Copy to C:\Program Files\Common\Files\ArcGIS\bin on a 32-bit Windows OS.
2. Run Haestad.Integrator from Start > All Programs > Bentley > WaterGEMS, Start > All Programs > Bentley > SewerGEMS or Start > All Programs > Bentley > HAMMER.
Please contact Esri for assistance with the ArcGIS patch or for information on when this fix will be included in a product update.
