| Product(s): | FlowMaster |
| Version(s): | 08.11.01.03 |
| Area: | Installation |
When installing FlowMaster version 08.11.01.03 the following error appears.
Error 1335. The cabinet file 'Data1.cab' required for this installation is corrupt and cannot be used. This could indicate a network error, an error reading from the CD-ROM, or a problem with this package.
1. Download a new copy of the installation file.
2. Temporarily disable security software to prevent it from interfering with the installation.
3. Right-click on the new installation file and select "Run as Administrator".
