| Product(s): | WaterGEMS, WaterCAD, HAMMER, SewerGEMS, CivilStorm, SewerCAD | |
| Version(s): | CONNECT Edition | |
| Area: | Output and Reporting |
The ability to save an animation video file was introduced starting with the CONNECT Edition release of Bentley’s OpenFlows products. It allows you to take the rich visualization experience you’re used to as a modeler and share it with others who may not have the software. Sharing a video can be a more powerful and effective way to communicate and present your hydraulic model results to others.
Note: this feature is found within the Time Browser tool and currently does not apply to Bentley HAMMER. To save the results of a transient simulation (such as an animation of a profile in the transient results viewer), you can use third party screen capture software such as Camtasia Studio, or possibly similar, free software.
1. Compute the model.
2. Open the Time Browser by selecting Times from either the Home or Analysis ribbon tab. The Time Browser will appear blank if the model has not been computed.
3. Open the Time Browser Options dialog.
4. Click the Record Animation button to launch the Record Animation dialog.
5. Specify the recording area.
6. Move the Record Animation dialog out of the recording area if you don't want it to be included.
7. Once an area is selected, click the Record button to begin the capture.
8. Once the recording has begun the Recording Dialog will appear. The animation is set back to the first time step prior to recording. During the recording process, the time step increment is automated.
Note: The recording can be paused by pressing the F10 key, and then resumed by pressing the F10 key again. To stop the recording either click the Stop Recording button, or wait until the entire simulation has played out. At this point the recording will stop automatically.
When a recording stops, the Video Player will launch. The Video Player can be used to play back the video which was just recorded.
Note: The Video Player can be used to play back previously recorded videos as well. An alternative way to launch the Video Player is by clicking the arrow next to the Record Animation button on the Time Browser and selecting Video Player.
The Video Player allows you to view the video which was recorded.
If the current video in the Video Player is the result of a recording, the user will be prompted to save the video if they attempt to close the Player prior to saving the file via the Save as… option.
Video files recorded by this feature can be shared with others (who may not have the software) or imbeded it into external content. You may notice a large file size for your videos. This is because the videos are recorded in raw format. You can use an external video editing software or conversion tool to convert the video to another format if needed.
Also, if you need to transmit the raw video file to someone else, it is recommended that you compress the file into a ZIP first. This should greatly reduce the file size.
Help: Recording Scenario Animations
Blog: Creating Shareable video files with Animation Recording
| Original Author: | Craig Calvin |
