| Product(s): | HAMMER |
| Version(s): | V8i SELECTseries 2 (08.11.02.31) |
| Area: | N/A |
The SELECTseries 2 release of HAMMER V8i includes many new features and improvements. This technote explores each change.
- Support for Newer Platforms
- Custom rating curves for air valves
- Additional four quadrant pump curves
- Additional unsteady transient friction method
- Projectwise integration changes
- i-model support
- Seed file support
- DXF export layer control
- Symbology definitions
- Microstation Integration Improvements
    - View associations
    - Tooltip customizations
    - Print preparation
    - GIS style
    - Multiple models
    - Detach and save-as Options
- Formula-based user data extensions
- Selection Tool for User Notifications
- Support for US Survey Feet
- Initial conditions improvements
    - New EPANET engine version
    - More Flexible Date/Time Formatting
    - Performance increase for controls
    - Pressure loss result field
    - Pump curve viewer improvements
    - Pump station element
    - Multi-select/delete (show profiles)
    - New network trace queries
HAMMER now support the following platforms:
The SELECTseries 2 release of HAMMER V8i includes 23 new predefined specific speeds, as selected in the transient tab of the pump definition.
In this release, the integration with Projectwise has been enhanced:
With the SELECTseries 2 release of HAMMER, you can now publish an i-model. An i-model is an immutable container for rich multi-discipline information published from known sources in a known state at a known time. Basically it is a portable, read-only copy of a model file that can be viewed by users that do not have HAMMER. The topology as well as the attributes and results can be viewed in MicroStation, Bentley Navigator and Bentley View. Since Bentley View is free, i-models provide a way for anyone to easily view data and results for a HAMMER model file. Note that detailed transient results (as seen in the text reports and Transient Results Viewer) are not included with the i-model, but you can include the statistical results, as seen under the "Results (Transient)" section of the properties. For example, max/min head, pressure, flow, etc.
Under File > Export, you will have a "publish i-model" option, which requires the i-model publishing engine (downloadable from selectservices.bentley.com). The i-model publishing engine shows as a prerequisite on the download page for HAMMER, but is only necessary if you intend to publish i-models. If you have no need to publish i-models, you do not need to download and install this optional component.
Seed files allow you to save project settings and data as a template (the seed file has a .wgs extension). You can then reuse these settings/data while creating new projects using the data from the previously saved seed file.
When exporting the plan view of a drawing to a DXF file, different elements can be placed on different layers.
You will now have a dropdown at the top of the Element Symbology manager, which allows you to configure which symbology should be applied. For example, you could have one symbology definition for steady state with certain annotations and color coding enabled, then another one for EPS, with different annotations and color coding enabled.
A number of improvements have been added to the Microstation Environment:
When working in the MicroStation integrated mode, it is now possible to associate scenarios and symbology definitions with MicroStation Views. This basically lets you see different scenarios and/or symbology definitions (color coding/annotation at the same time, by opening multiple MicroStation Views.
A "mode" button is available for both Element Symbology and Scenarios:
Example:
While using the Microstation integrated mode, the new tooltip customization feature allows you to define custom text to appear when hovering the mouse over an element in the drawing. You can enter static text and/or dynamic annotations, similar to element symbology annotations. This can be a convenient alternative or supplement to annotations, as you can quickly view data just for the element you point to.
Note: be sure to right click on the tooltip customization and choose "make active".
A single dgn file can now reference multiple HAMMER models, by using the MicroStation Models feature. Simply attach a new model to the dgn, then attach the HAMMER model. Here is an example workflow:
Print Preparation is a special tool that was not readily available in previous versions. It is now included with the installation of HAMMER, making it easier for you to print your model when using the Microstation integrated mode. It can be accessed from the bottom of the Tasks list:
Print preparation is essentially a printing wizard; first you select a template, then follow the prompts, selecting the area of the drawing and rotation for the main viewport and detail views. Several templates are included with HAMMER: ANSI, ARCH and ISO:
You can now choose between CAD (zoom dependent) or GIS (zoom independent) drawing style when working in MicroStation. With GIS style, symbol and text sizes stay the same, regardless of your zoom level.
In this release, you can now detach a HAMMER model from the dgn and save it to a new location.
In the past, a user data extension always contained static, user-entered information. Now, you can create a user data extension whose value is calculated based on other existing fields. For example, you can create a field whose value is equal to the square root of the difference between one input field and another user data extension. The possibilities are endless. In the below example, a field has been created for the Orifice element, which back-calculates the required pressure drop value to be used, for a given diameter and "typical flow" (entered in a different, static user data extension).
You can now select US Survey feet as a length unit.
The following new features apply to the initial conditions only.
The SELECTseries 2 release of HAMMER V8i includes an upgraded version of the EPANET hydraulic calculation engine: 2.00.12. This is the calculation engine used to compute initial conditions. This version includes enhancements to control valve convergence (such as PRVs in parallel) and water quality computational changes. Several new calculation options are available to facilitate the convergence enhancements.
You also now have control over which version of the calculation engine to use, mostly for compatibility reasons:
In previous versions, time was often displayed in a fixed way, and in some cases was not consistent. for example, the calculation summary displayed as 03:00:00 whereas data tables displayed as 3.00. In V8i SELECTseries 2, you can now customize the time format.
Performance has been improved when working in the Control manager (Components > Controls). Meaning, navigation through the Control user interface should be faster, especially for larger models with many controls.
Pressure Loss and Pressure Loss Gradient have been added as standard result fields.
In previous versions, the pump curve viewer (right click on a pump and choose "pump curve") only displayed the head curve, for the current time step. The pump curve display has been improved in V8i SELECTseries 2 and you now have the ability to:
Example 1: Current time with head and efficiency:
Example 2: head and efficiency at multiple times with different speeds:
The SELECTseries 2 release of HAMMER V8i introduces a new element type called a pump station:
A pump station is a polygon element used to model multiple pumps that are in the same structure, serving the same pressure zone. It provides a graphical way to display the pumps associated with the station. A pump station is not a hydraulic element in that it is not directly used in a hydraulic analysis but rather it contains a list of pumps that are within the "station".
A pump station displays which pumps are in the station by dashed lines connecting the pumps with the station polygon centroid. A pump does not need to be inside the polygon to be a pump assigned to the station and pumps inside the polygon still need to be assigned to the station. Select the pump station from the "Pump Station" attribute of each individual pump.
In HAMMER, pump stations are only used for visual and organizational purposes, so you can group together pumps that are in the same "station". In WaterCAD and WaterGEMS V8i SELECTseries 2, the pump station feature allows you to do a Pump Combination analysis, where you can view combined pump curves for one or more pump within a given station. This pump combination analysis feature is not available in HAMMER, but the pump station element is included because HAMMMER, WaterCAD and WaterGEMS use the same file format. Meaning, you can lay out and configure your pump station in WaterGEMS/CAD, open the model in HAMMER, do a transient analysis, and open it back up in WaterGEMS/CAD without losing your pump station information.
You can now use the CTRL (control) and Shift keys to select multiple items in lists. For example under Components > Controls > Conditions, you can click one condition, hold the control key and select several other conditions, then press the delete key to delete them all at once. This feature applies to:
Three new network tracing queries have been added:
OpenFlows Product Tech Notes And FAQs
