Modeling a vacuum sewer system
Product(s):SewerCAD, SewerGEMS
Version(s):08.11.XX.X, 10.XX.XX.XX
Area:Modeling
Can a vacuum sewer system be modeled using a OpenFlows product such as SewerGEMS or SewerCAD?
Designing vacuum sewers is significantly different from gravity and pressure sewers. The underlying calculations of a vacuum sewer are fundamentally different from the ones used by SewerCAD and SewerGEMS
However, manufacturers of vacuum pumps usually help engineers with hydraulic design, so it may help to contact the manufacturer for help.
