| Product(s): | WaterCAD, WaterGEMS, HAMMER |
| Version(s): | 10.01.01.04 |
| Area: | Output and Reporting |
With a Bing Map active, a blank page appears in the report and printout of the plan view of the model as well as flushing operator's reports.
This is a known issue with version 10.01.01.04 (reference # 904768). You can check your version under File > Help > About (or Help > About for V8i). To resolve the issue, contact Technical Support for the latest cumulative patch set for version 10.01.01.04, or upgrade to a newer version when available.
Downloading OpenFlows | Hydraulics and Hydrology Software
How to add background aerial and road map images to your model
