| Product(s): | SewerGEMS, CivilStorm |
| Version(s): | V8i, CONNECT Edition |
| Area: | Calculations |
When using the RTK method with catchments, computing the model takes a very long time. This may appear to happen suddenly (when performance was faster in the past, and something was changed)
This has been known to occur in the past when using certain RTK parameters. For example if the K parameter is too high (typical range of 1.5 to 2.5), or the T parameter is too low. Try adjusting the RTK parameters; when they are within a normal range, performance should be much faster.
Also, performance improvements for catchment runoff calculations were introduced starting with the CONNECT Edition. If you are not already using the CONNECT Edition, upgrading is recommended. See: Downloading OpenFlows | Hydraulics and Hydrology Software
