| Product(s): | SewerGEMS, CivilStorm, StormCAD, SewerCAD | ||
| Version(s): | 08.11.XX.XX | ||
| Area: | Layout and Data Input | ||
| Original Author: | Mark Pachlhofer, Bentley Technical Support Group |
Pressure pipes are left out of a LandXML file that is imported to a OpenFlows Storm / Sewer product.
Pressure pipes in a Civil3D file are not importing, when exchanging data via LandXML format.
Currently, AutoCAD Civil 3D doesn't support the export of pressure pipes to a LandXML file. So, since Civil3D does not export them, the OpenFlows product cannot import them since they do not exist in the LandXML file.
