| | Product(s): | WaterGEMS, SewerGEMS, CivilStorm, StormCAD, PondPack, SewerCAD, HAMMER, WaterCAD | |
| | Version(s): | 08.11.XX.XX, 10.XX.XX.XX | |
| | Area: | Output and Reporting | |
How do you filter the FlexTables so only active elements are present in the table?
Problem ID#: 77171
- If inactive elements are present in the flex table you can filter contents of the table by the attribute "Is Active?"
- To do this, right-click on the "Is Active?" column of the FlexTable and choose Filter > Custom, which will open a new dialog. (If you do not see 'Is Active' column, you need to add it, right click>Add column)
- From the table on the left, choose "Is Active?" from the list. Then choose the "=" sign from the items in the middle.
- On the right, click the Unique Values icon and then select True from the list. Once completed, the FlexTable should only show the active elements.
Filtering a flextable on "Zone" = 'None'
Filtering a flextable to only show fields that pertain to a specific solver
