Product(s): | Bentley SewerCAD |
Version(s): | 08.11.XX.XX, 10.00.XX.XX |
Area: | N/A |
This can be done in the flextables for each element type, using the Export button in the upper left corner. For example, open the conduit flextable and click Export to export your conduits to a polyline shapefile. Click the Export button in the manhole table to export your manholes to a point shapefile.
Converting your model elements to shapefiles
To filter the flextable to only show elements included in a particular selection set, you can use one of two methods:
See the following support solution for details:
Filtering the Sanitary Load or Inflow Control Center by attribute or by selection set
Using Manning's equation as shown below, SewerCAD calculates the Capacity (Full) of a pipe. The Capacity (Full) is based on assumption that the flow through the pipe is absolutely at normal flow condition and the normal depth equals the rise of the pipe (for circular pipe the rise = diameter)
Q = k/n*A*R^(2/3)*S^0.5 [Manning's Equation]
At normal flow:
• The water depth, flow area, flow, and velocity distribution at all cross-sections and throughout the entire length of pipe remains constant.
• The Energy Grade Line (EGL), Hydraulic Grade Line (HGL) and the Channel Slope are parallel.
• The velocity/depth ratio is constant.
• There is no acceleration or deceleration of the moving mass.
However, in SewerCAD, water does not flow at normal flow; it computes a varied flow profile. So, the HGL slope can be changing over the length of the pipe and thus depth can be different than normal depth and this "full capacity" value may not be good for comparison.
Now, in a SewerCAD model, increase the length of the pipe whose Flow is exceeding the Capacity (Full), say by 10 times and then look at the profile of that pipe. You will notice that the upstream end of the pipe may flow full (surcharging). If not, increase the length of pipe.
What this means is, the initial pipe length is not long enough to create the surcharge even though the Flow exceed the maximum capacity and therefore the HGL in the profile is not above the pipe crest elevation.
Because air valve status can change, they can lead to instability in the model especially if there are many air valves in the system. To improve the stability of the model, it is desirable to force some of the valves closed. This can be done by setting the property "Treat air valve as junction" to True for those valves that are expected to be closed anyway.
OpenFlows Methods Product Tech Notes And FAQs
General SewerGEMS For ArcGIS FAQ
